[SOLVED] MSI B450-A PRO MAX and Corsair 16 GB (2x8GB) DDR4 3200 MHz (CMK16GX4M2B3200C16) nxp support
Unat2025
Commendable
Jun 5, 2019
20
Hi. I'm looking for RAM for this mlb. Ryzen 7 3700x my cpu. But this RAM is not in list of supported, will it work ok or not?
for example this ram is in list for MSI B450 TOMAHAWK MAX. And this mlb is so similar. Strange(
You should be able to select the XMP wanted in BIOS and then save the XMP settings.
Manual input of settings (RAM frequency, voltage, timings) in BIOS should only be necessary when wanting settings other than that provided by XMP's, such as in overclocking. But in some cases manual input may be required when the XMP's do not work as expected or wanted.
