Alright starting off my problem is that an MSI B450 gaming plus motherboard refuses to boot and only shows the EZ troubleshoot CPU LED at all times.
Im using 2 sticks of 8GB DDR4 RAM and a Ryzen 3 2200g.
This board is supposed to be 2000 series ready but apparently not?
-Ive tried updating the BIOS using the USB BIOS flashback plus.
-Ive checked it with minimum confguration (only the psu, cpu and a stick of ram).
-ive checked for shorts and found nothing.
-ive tested both sticks of ram and nothing.
-ive tried some odd trick with turning onthe PSU switch and Case power switch at the same time and nothing.
-Ive tried reseating the CPU and nothing (its not cracked, has no bent pins or anything).
-The power supply is in working order as ive been using it on my previous build till today ( got the parts today and started upgrading), and cpu pins are connected as well.
As of now the only thing i havent tried is using an am4 athlon or testing the ryzen 3 on another am4 motherboard (which i will do later when i get to a friends house to borrow his).
Im stumped, these parts are brand new and i doubt/dread they came faulty.
If anyone has any possible suggestions no matter how fringe id really appreciate it. Thanks in advance.
