[SOLVED] MSI B450 Gaming Plus Max CPU LED
Nov 29, 2020
Hi all,
I built this machine about 5 weeks ago and everything went well.
Plugged it in, turned it on and Golden!
Updated all drivers
No overclocking and all setting are stock.
Just this morning I have the EZ debug CPU LED out of the blue.
I have checked all connections, pulled the CPU to ensure proper seating and no damage.
I have attempted to update the BIOS using the USB flash function but I'm not sure if this is actually working.(I read that the machine will power cycle after the process ,but this did not happen)
So.....Before I get too far down the wrong rabbit hole I though I would seek a bit of advice. I'm not PRO and only have moderate knowledge.
Any ideas?
Thanks in advance.
Hardware:
MSI B450 gaming Plus max
Ryzen 5 3600 CPU
GTX 1650 Super GPU
G.Skill DDR4 3200 x 16GB
Corsair CX 600M PSU
reset the cmos, either with a jumper should have been supplied with the mobo 2 pin jumper turn off PC unplug then use the bat1 connector with jumper, or turn off PC unplug then remove the disk shaped battery on your mobo leave for 5 - 10 minutes then return battery.
