[SOLVED] Msi b450 tomahawk max 4 dimms max frequency
Sa1Ko
25
Does anyone know from experience what is the highest frequency this mobo can achieve with 4x8gb ram sticks of g.skill tridentz rgb gtzrx 3600c18 and a ryzen 3600x?
Ideal combo is 3600MHz but Cl18 is too much. See what you can get with Cl16 or better although you may be hard pressed to have them work over 3200MHz. It would be much better to get 2x16GB
Thanks for the replies. Unfortunately i have these rams already at home. So is it better to sell one set and try to tighten the timings on the other? Like going for 3600 c16 if i am Lucky?
