[SOLVED] MSI B450 Tomahawk MAX show VGA red led
Apr 6, 2020
7
Ok, so I built this pc and I'm facing a problem. I have an MSI B450 Tomahawk MAX motherboard paired with a Risen 7 2700x. When I try to boot it the EZ Debug LED turns on for the CPU for a second then turns off. Then the VGA red led turns on and stays on. The funny part is that I don't have a GPU installed. So I don't why it shows me this error when there is no GPU installed? Thanks!
It's on because there is no gpu. The 2700x has no igpu. So in order for the system to post and be usable you'll need to get a video card.
