Hi, I have build this PC 1 month ago and it was working properly.
Build Specs:
MSI B460M PRO VDH WIFI MATX
Intel Core i3 10105F
ADATA - XPG GAMMIX DDR4 1x8 GB
Crucial BX500 250 GB SSD
Galaxy GTX 650 1 GB (Form OLD PC)
Antec VP450 Plus 450W PSU
I swapped the VGA cable of the GPU with HDMI cable and it was working without any issues initially and then the issue started, while powering on the system debug VGA led is turned on and then its not going into boot mode, so i have turned off and on the system several time on that day and it didn't workout.
After the next day morning replaced the HDMI cable with VGA cable and then when i power on the system it start normally without any issues and restarting the system also works fine, but when i shutdown the system and turn it on again it gets stuck into the debug VGA led turned on.
And its not working for the whole day and i have to wait till next day morning to start it and its started normally without issues then repeats the same like if i shutdown it gets stuck on the debug VGA led turned on.
Please guide me to diagnose the motherboard and its connected peripherals.
And below are things i have tired so far:-
1.Swapping the single RAM stick with other slots.
2.Cleared CMOS using the jumper pin.
3.Re-seating the GPU in the PCIE slot.
4.Replaced the old VGA cable with the GPU and removed HDMI cable.
Kindly help me guys.
Build Specs:
