Question MSI B550 - Advice for a build
Feb 7, 2022
I have currently a i3-4th gen with R7 240 as graphics card, so maybe i'm not that up to date with recent parts, that's why i'm asking for help
My objective is running on most games (cyberpunk, doom, R6, NMS, etc..) at high or ultra with stable 60fps but not something crazy like in 4k, doing some work con CAD or design software in general and "to be easily" upgradable.
Currently i have a XFX RX 6600 XT SWFT 210 and the build i have in mind is more or less like this:
Now, the question is...
I want to spend more or less $450 (flexible) on CPU and MOBO, i'm pretty solid about the 5600X, but i'm not 100% sure about the MOBO
I need to get a better MOBO and cheaper CPU, or is alright as it is? There are other MOBO way better than this one at about the same price (maybe getting a little past the $450 budget)? Some warning or tips i need to know about the MOBO?
I don't have problem about getting an Intel CPU and MOBO, if there are reasonable better choice instead of this one above
And for the last thing, i have not decided the case yet, if you have one or two you want to propose, i will be happy to see.
It's actually my first build, don't kill me
