Question Msi b650m gaming wi fi sound issue
pain_86
37
Hello! I recently build a system with MSI b650m gaming wi fi and i have a very weird sound problem. I'm using the l out mobo output with a stereo system Sony. I have a very annoying static buzzing sound. I tried many things, settings and when i changed the cable things got better, but i still have tis sound buzzing when no audio is playing. It's gone when i play music and stuff, but when i close the youtube lets say the noise is back until i start something to play. I tried with other speakers and it is the same, but when i plugged headphones in the i/o case jack the noise was completely gone, only in this front jack. Any thoughts from what is causing it? I read that some people have it due to win 11issue, i'm worried that it might be the motherboard...
here are the full specs just in case anyone wants to know :
Ryzen 5 7500f
msi b650m gaming plus wi fi
sapphire pulse rx 78000xt
corsair vengeance 6000mhz cl30
western digital blue sn580 2 tb ssd
arctic freezer 36
seasonic g12 gc 12 750w
Lian li lancool 216arx
What BIOS version are you on for your motherboard?
Did you make sure your 3.5mm jack is fully inserted into the stereo audio output port on the rear of the motherboard?
Did you install the OS in offline mode and the latest drivers for your motherboard manually in an elevated command or did you install the OS with the internet connected and let the OS download and install drivers it thought was right for your platform?
There's only so much you can explain through text that you're in need of other media to illustrate what you're experiencing, to convey the message. Please pass on a video/audio clip of what you're going through.
Do you feel a mild tingling sensation when you touch the metal part of your case while your feet are making contact with a tiled(non-wooden, non-carpeted) floor?
Bios - American megathrends international llc 1.61, 6/27/2024
Yes im sure the jack is inserted correctly
The OS was installed by the guys from the store that i purchased the parts, they build the PC. I installed the msi drivers by myself when i got it.
No i don't feel any tingling when i touch the case
I don't know how to upload audio here..?
https://www.msi.com/Motherboard/B650M-GAMING-PLUS-WIFI/support
I would flash to the latest BIOS version, then clear the CMOS. Then manually reinstall the latest chipset drivers sourced from AMD's support site. Then uninstall the audio drivers, then manually install the latest audio driver sourced from MSI's support page in an elevated command, i.e, Right click installer>Run as Administrator.
You host them on a site like Imgur or their ilk, then pass on a link for us to see.
Ok i uploaded the noise in this site...be sure to volume up so you can hear it clear. Here's the link :
https://we.tl/t-BfIHsrQQ5P
