As long as it comes with an adapter it'll be fine, but since 12VHP cables can require a 650w or higher PSU to be fitted with them or purchase for use, and a system with this card may not be using that size PSU, there could be a problem.
I thought this was part of the point of the 12VHPWR or 12V-2x6 is that the 4 signal pins indicate the power of the PSU so that the card can determine if enough power is available to feed the GPU. So that all GPUs and PSUs, from low power to high power could use the same connector and ensure that the required power exists. There's no reason it can't be used on a lower power card like this.
