Question MSI EzDebug LED
iKaezon
Hi there,
I have this very occasional issue that occurs maybe once a week if anything. On a normal successful boot, the EzDebug LED lights on the mobo go from CPU, DRAM, VGA, BOOT, in that order then the PC boots up.
However, sometimes the led light will go from CPU, DRAM VGA, then skip BOOT, and then go back to CPU for half second then the PC shuts off. So essentially when I turn it on, the fans and rgb and all come on, then the PC shuts itself off 3 seconds later. After that, I am able to boot up again and everything is fine and the issue won't happen again for a while
I've already replace my PSU once and reset the CMOS battery twice.
Essentially I would like to know if this is a serious issue as it does not seem to be harming my PC at the moment. My temps, etc. are fine. However, I would like to know if this is normal or what is causing it.
Specs:
  • MSI MPG Z490 Gaming Edge Wifi
  • i7 10700k
  • MSI RTX 2070 Super
  • Corsair Vengeance 2x8gb
  • Corsair H100i AIO
  • Seasonic Focus GX750
