MSI Fan Control Softwware?
ZeusGamer
Admirable
Do any of you guys know where the fan control is for MSI motherboards? I mean I know where it is. But I don't really want to download all of the utilities. I just want to be able to control my fans while booted to my current OS.
My motherboard is MSI Z97M Gaming by the way.
Thanks guys.
I will download Command Center.
The reason I asked is because I didn't want to go to the UEFI BIOS to control the fan. I just wanted to change them
while I'm booted in Windows 7! Anyway, thanks again.
For Posterity since this is the top result for a search on "msi fan speed control" which I searched a lot to try to figure out how to get my MSI motherboards system fan under the 50% threshold. This should also work for the 25% CPU limit for minimums. Especially annoying for the 50% fan speed lock system fan 4-pin that defaulted my fan to hurricane loud....while the case temp was 42 c. Problem Solved!
https://youtu.be/NZn9xnue0Dk
