The smart fan control on my z97 gaming 5 only works when I am in the hardware monitor section of the bios. When anywhere else, my fan automatically ramp to max speed.
In the bottom right corner of the main interface (not the temp gauges) click 'Settings'. Then choose the second tab 'Fan'. Check the box marked 'Enable user defined software automatic fan control'. Set a temp/speed curve to your liking. Click 'OK'. Done.
wouldn’t this be for the gpu fans and not cpu fans?
My bad, try this https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwiOgeS07OnWAhUB8CYKHXG9BrQQtwIIPDAC&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DNZn9xnue0Dk&usg=AOvVaw12ZpCWTfmVxqwoYQHCZdYG
While this does technically solve the problem, it requires you to start the software every time you turn on the pc, is there any way I can fix this permanently?
