MSI FM2-A75ma-e35 USB 3.0 Problems
Yeah, the USB 3.0 wont work on the motherboard, or on the front panel. I have double checked that the USB 3.0 connector is plugged into the motherboard for the front panel port.
The USB 2.0 are working, but not the 3.0's. I have also noticed than when I plugged in my Toshiba 3.0 external hard drive, the light flashes blue ( it glows blue for usb 3.0, white for 2.0 ), then there is no light from it, and it is not accessible. I will look at my manual.
Ok, I checked the manual, and it said nothing about enabling it in the bios. It only said that the USB 3.0 will not work if you are using a 2.0 cable, but I know that my cable isnt 2.0 .
