Question Msi ge63 raider rgb 051 HELP!
partiesplayin
96
I decided to try and undervolt the cpu to reduce temps. I was in performance mode all cores at 3880mhz +- with the Dragon Center. and i used intel xmt to reduce the cpu core voltage to -.105 v , it said that it needed to restart for the settings to take effect. i closed some applications and hit okay. During the restart cycle it hung i left it there for almost 5 minutes, then decided to shut it off manually. now the laptop will not get past the msi logo and cant access the bios menu .PLEASE HELP How can i fix this ?
i have tried to
hold del key on boot to get bios
also try holding f3 or f8 or f11
try and boot from windows usb installation media
reset bios defaults
reset EC (power reset) look for pinhole in bottom center of machine
hold power button down for one minute
Report to moderator Logged
