[SOLVED] MSI Geforce GTX 1650 Super Ventus XS OC 4 GB card problem
punkyfish
64
Hi just installed an MSI Geforce GTX Super Ventus 1650 XS OC card and it shows in device manager and fans spin but the Geforce logo on the card will not light up. Changed cables etc but nothing.
This is my PC: https://uk.pcpartpicker.com/user/Punkyfish/saved/#view=X8Hzf7 Grateful for any help. Doesn't show in Dragon Centre in Mystic light. Tried Nvidia LED visualiser, card not supported and nvidia weren't able to help.
Is it faulty? Thanks
That 'stock photo' is not a stock photo for your specific MSI Geforce GTX Super Ventus 1650 XS OC.
That photo is of the GeForce GTX 1650 Super Founders Edition.
Hi, thanks for the quick reply. The 2 fans spin and the card is recognised in device manager etc. I’m sure the card should light up...concerned if it does light up and it isn’t it could end up frying everything else or stop working. Would rather get a replacement if that’s the case. It says MSI and the geforce bit looks like it should light up . Stock photo below
