Question MSI Geforce RTX 2060 Ventus XS 6G OC normal maximum load temperature
Feb 15, 2019
8
Hi, nice to meet you all. I have bought an MSI Geforce RTX 2060 Ventus XS 6G OC on last Monday and safely arrived on my hand yesterday. Before that, I did some research about the differences between MSI Ventus and MSI Ventus XS. If I'm not wrong, their differences is only at the cooling system and their size. Apparently despite the not-so-different looks, MSI Ventus have more advanced cooling system and only 1 cm longer than MSI Ventus XS. Both graphic cards' boost clock is the same. CMMIW. I tested run my new graphic card in some games including Shadow of The Tomb Raider and PUBG at maximum settings, and did some stress test in Furmark. The temperature reach 81* C at maximum load. I thought the temperature is too high so I opened the side panel of my case. The temperature went down and stabilized at 74-75 C. I'm using 5 case fans, 2 fans intake at the front, 2 fans exhaust at the top, and 1 fan exhaust at the rear.
The questions is:
  1. Is it normal to reach 81* C for an MSI Geforce RTX 2060 Ventus XS 6G OC?
  2. Is it safe for daily use?
  3. Is the case fans setting causing this?
Thank you and sorry if my English is bad.
