MSI GT70 2PC Static Sound on Battery Charger
HenryP9626
35
When my gaming laptop is at 100% my charger makes a sizzling sound. It's sounds like static, this has been happening for 4-5 months now. I had no issues at all when it happens, but I want to know if that is a really bad sign or it is normal.
It only happens when my battery is at 100% and I am just doing casual things on the computer, like watching movies, browsing the website, etc. When the battery is at 100% and I am gaming it does not make any static noises.
So if someone can tell me if this is normal or not. Thanks, also I want to know why it makes the sound. If it is not normal then what should I do? Oh and I always have my charger in my laptop all day, 24/7, unless I bring it with me to work, or school.
Well, it's pretty normal, static in adapter, whether they're charging, or not at all. If You're annoyed by the static, change the adapter, if You don't mind it, keep it. It's no big deal. Sometimes the adapters tend to die, right after they do this static sound for long time. Though, there's a little to no chance it may hurt Your notebook.
Is the static sound going from the charger, or from the notebook? If it's notebook, it's most likely convertor inside the notebook, that converts the voltage within the notebook, or some adjacent part. You should RMA it in that case. If it's the adapter, change it.
Its coming from my adapter, that I had for 8 months.
Do you know why it does that? As I am curious to know.
Source of this article is from here. It's not my text, I didn't write it, nor own it!
Most power conversion devices contains coils, such as transformers or inductors. These components use electromagnetism to convert AC mains power to low-voltage DC power. The varying magnetic fields generated by these components can cause them to physically vibrate at high frequency, resulting in a high-pitched noise.
Most modern AC adapters are switched-mode power supplies. The internal switching frequency of an SMPS is typically low when unloaded and increases with load up to a certain point depending on the design. The no-load frequency is often low enough to be within the human hearing range. In addition, in low or no-load situations, the PWM used to regulate voltage at the inverter stage will be at a low duty cycle creating a "spikey" output profile which is more prone to causing vibration in coils, and the transformer itself will tend to vibrate as well (see Daniel R Hick's answer below for more details). Together, these can lead to audible noise especially in cheaper units which fail to suppress this noise.
Under load, a properly functioning SMPS should operate at a frequency well above the human hearing range, typically 50 KHz or higher (although some older designs operate at 33 kHz). However, the same noise can occur under load with a poorly designed or defective power supply as the coils may vibrate under electrical stress at a subharmonic frequency.
Coils used as inductors or transformers in other electronic devices, including those on motherboards, graphics cards, or other computer components, can also vibrate during operation. As such, a defective device can generate audible coil whine during operation.
This is why you sometimes see weird gobs of glue on coils inside electronic devices. The glue helps reduce the vibration and noise the coils generate during normal operation. It is entirely possible for users to apply glue onto coils using a glue gun to suppress coil whine, and people have successfully done so on their computer parts. However, you generally can't do this easily on small wall chargers of the sort you mentioned without risking damage to the charger or exposure to potentially dangerous voltages.
Ultimately, a whining noise isn't necessarily a sign of trouble in cheaper wall chargers when they are unloaded. However, a computer PSU or laptop charger that generates coil noise especially when under load may be defective and you may want to consider replacing it.
More information on coil noise can be found in this Wikipedia article.
Thanks man and oh yea, get The Witcher 3: Wild Hunt. IT'S AN AWESOME GAME!
