Question MSI GTX 1080 Aero - Please Power Down and Connect PCIe Power Cable(s) For This Graphics Card
Aug 24, 2018
11
I recently purchased a GTX 1080 Aero however whenever plugged into a system it reads 'PLEASE POWER DOWN AND CONNECT THE PCIe POWER CABLE(s) FOR THIS GRAPHICS CARD' on the screen. I have tried multiple power supplies and 2 motherboard but the issue is persistent. I have also noted the GPU 6 pin power which seems rather odd. All other cards I look at seem to be 8pin at least.
Metal Messiah.
Commendable
Mar 28, 2019
2,154
447
1,790
61
What all POWER SUPPLIES did you try ? List the model number/brand. Any decent high quality PSU must have at least TWO 6+2-PIN PCI-e connectors. Your GPU requires a SINGLE 8-PIN, so you have to use one 6+2-PIN cable.
You need to plug one 6+2-pin pci-e cable to the GPU to power it up.
11
I used a Corsair VS550 and a Truepower Trio 550, both which have the necessary PCIe connectors.
Metal Messiah.
Commendable
Mar 28, 2019
2,154
447
1,790
61
I just took it apart and the chip itself reads, GM204-400-A1. This seems to be the chip for a GTX980
Well, that's HUGE bummer then. From where did you BUY this card ? Was it used or brand NEW ? It looks like someone slapped a GTX 980 instead of 1080, inside the video card's box. That chip is indeed the GTX 980.
From which shop, or marketplace did you actually purchase this card ?
Aug 24, 2018
11
I purchased it used from a Computer shop online, this shop generally has very good feedback but it seems this one slipped through the cracks. They have already accepted the return so all should be okay.
I looked at the power connectors on the PCB and it clearly shows that the other 8pin had a tacky de-soldering job done to it, perhaps to try and get the card to fit with the casing.
Aug 24, 2018
11
Okay, that's fine then. Glad to hear that. Btw, what do you mean by "the other 8pin" ? How many connectors does this card have ? From that PIC which you have posted, it only shows a single 6-PIN.
It looks to have the 8pin connector removed via a very janky solder job, they probably removed the 8pin to to get it to fit in the casing.
