MSI GTX 960 help
cto520
27
Hello,
Running GPU-Z, I took a screen shot of my resource usage and don't know how to understand it, if I am using too many resources or if this is normal.
https://www.techpowerup.com/gpudb/b3239/msi-gtx-960-gaming-4-gb
Alright, let me run you through the important parts.
The GPU memory and core clock
This is the speed on which your graphics card is operating, if you start playing games for example, this will go up.
GPU tempature
Speaks for itself, the tempature of your GPU. Under load, this can safely go up to 80 to 85 degrees celsius. For idle, 30 to 40 degrees is fair.
Fan speed
This speaks for itself as well, the speed (in %) at which your fans are spinning. This is on 0% because they start cooling at a certain tempature. (I think it was like 60 degrees, not sure).
Memory used
The amount of VRAM currently used by your GPU.
EDIT: Your resource usage is normal.
GPU tempature
Fan speed
Memory used
