MSI GTX 970 4GD5T OC - Overclock Setting Help
luckystrikes
151
Hello Community,
I am planning to overclock my Video Card soon and need help from the community here.
As I don't have any clues to what Mhz is safe to overclock my GPU to.
This is the GPU that I recently bought.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127833&cm_re=msi_gtx_970_4gd5t-_-14-127-833-_-Product
Would anyone help me around getting the safe amount as to overclock my GPU?
I don't want to overclock way high but just enough to see a bit faster mode?
I am going to use MSI Afterburner.
Thanks in advance !!\
Cheers
Overclocking GPUs really doesn't yield decent performance increases. You'll get a max increase of about 4fps on an exceptional overclock.
Not overclocking also saves you the worry of de-stabilising your GPU.
