MSI GTX 970 No fan speed or RPM in GPU-Z
Sethhe
13
When I go into any software such as GPU-Z Iit does not tell me my fan speed or RPM for my MSI gtx 970. Is this bad? I'm sure they are spinning as I'm able to run Skyrim on ultra with mods and I ran Unigine Heaven Benchmark on high at 100fps with the GPU running at 60 degrees C. So there can't be a problem, right?
1- your gpu wont need/spin the fan until u exceed 60C
2- u can use MSI after burner if u want to control the fan speed
3- there is no problem at all the card will only throttle at 95C~100C
so as long as your max temps are bellow 85C you're fine
