MSI GTX670 OC using system memory
s4vvy
4
Hello Guys,
I got my MSI GTX 670 twin Fozr OC today which replaced the old HD 5770. My system settings show that i have 2GB less memory than i should. I went into Nvidia's system profile and there is shows 670 using 2GB system memory. My 5770 never did that on the same MB (Asus P7P55-E Pro)
I have even tried to disable VT in BIOS but to no use.
System : i7 860
RAM: 6GB (4GB available)
I cannot understand why would such an advanced card do this?
Many thanks for any help.
s4vvy
4
Yes i did, infact i just reinstalled Fresh Win 7 Ultimate x64 after default BIOS setting. MSI live update does not detect my MB .. So does that means my MB is incompatible.. Its really not that old.. Not sure what is going on..
Savvy
27
SOLVED: Not sure how but seems like there was a CMOS problem.. Did the reset 3 times.. and this worked..
In regards to MSI Live and MB.. Well if it does not detect your Motherboard or if there are any compatability issues there is a old legacy ROM which you can flash to the card for old MB compatability.. I was almost about to do that but CMOS clearing worked .. well kinda the 3rd time..
Thanks a lot guys..
Keep up the good work..
