MSI H310M PRO-VH Crashed While Streaming Now Ez Debug Blinks Once With No Power
Oct 3, 2018
I was streaming a game last night and my computer just shut off. When I started looking at the box everything was super hot. Not just one particular part, everything I touched was radiating heat. I wonder if running a stream was too much for the computer? I have been PC gaming for 20 years with plenty of long sessions and I have built dozes of computers yet I have never seen it where the computer shuts down and is 100% dead after. Usually something spins or happens.
My mother board is a MSI H310M PRO-VH. The processor is an 8th generation i7 and is cooled by a Corsair all-in-one water cooling system. When I ran some early benchmarks it was running around 30 deg C.
I unplugged all the stuff I could such as the hard drives, dvd drive, graphics card (geforce 1080) to try to get some sign of life. With just the power supply plugged in, if I pull out the 24 pin connector and put it back in the mobo, the 'Ez Debug' light blinks once and nothing else happens. A very fast white light that blinks. No fans, no anything else. The MSI web site is broken and I can't get the manual so I have no idea what one white blink means.
This leads me to believe the power supply is dead. I just ordered a new one on Amazon. I just wanted some feedback. This could be a huge pain trying to replace each part once by one until it works again.
Has anyone ever heard of streaming causing a PC to just get fried like this?
Update:
I have a Apevia ATX-WR580W power supply. I just took the computer apart and tried the "paper clip" test on this power supply. Noting happens. Fingers crossed that it's just a power supply.
sounds like there may be more then one issue or one issue that caused a lot more failures. the cpu running hot could be the pump failure or lack of power from the cheap low waatge unit you were using. look at seasonic 650w focues units. on the gpu card may be bad driver or bad power that kept the fans from spining. make sure the fan move at post. if not use msi after burner see if the fans move. if not use ddu in safe mode see if the fans will move. the white debug led on the mb is power good led. if it flashing it telling you power is rippling into the mb and in not clean.
I just got my new power supply and tried to hook it up. It's a EVGA SuperNOVA 850 G2. This time the Ez Debug light does nothing. I hear a very faint clicking noise come from the PSU when I hit the power button. I am thinking I fried my mobo.
OK. So I dug deep and fixed it. It was not powering on so I took out the mother board and plugged in the PSU on the table. It finally spun up! Slowly I put back each cord. When I got to the SATAs it would stop turning on again. I replaced all the cords that go to the new PSU with the cords it came with and everything worked again. There where cords that squished under the mother board before, I wonder if the heat from the mother board wrecked the old SATA cords? The new cord placement is no longer under the mother board and it works!
