I am currently experiencing audio problems with my computer. When I plug in my headphones, the computer does not detect them and I receive the "No speakers or headphones plugged in" message. The headphones are also not listed in my playback devices. When I check device manager I have no warnings for my sound devices. I have tried updating and reinstalling the msi audio drivers. I have also tried the default windows drivers as well as the generic realtek audio drivers. I have tried every setting in the realtek hd audio manager and the best I can get is to have the pc output audio to speakers that aren't plugged in (hd audio second output). I have also tried giving audiopointbuilder and audioserv more permissions. If I use a usb dac, i get sound but it is muffled and there is also a lot of pc noise over it. I even tried using a Lubuntu live disk to check if it was the OS but I had the same problems, including the same usb problem. I am debating simply getting a new motherboard if that is the problem, but then I should be getting usb audio. I have also tested the usb dac on another computer so I know it works. Microphone input also doesn't work. And I have tried both the motherboard audio jack as well as the case audio jack. I have even tried unplugging the case audio header. I did a complete OS reinstall but that didn't work either. Any help is appreciated.
CPU: Intel Pentium G3258 4.3ghz
Motherboard: MSI H81-P33
Audio: Realtek ALC 887
Case: Antec VSK-4000E
OS: Windows 10 pro (All updates installed)
