MSI H81M-P33 motherboard compatible with Power color AMD radeon HD6570 2GB DDR3 Graphic card
Blackstarwm
Hi all
I own MSI H81M-P33 motherboard and would like to check if powercolor AMD radeon HD6570 2GB graphic card is compatible to my motherboard?
check the motherboard manufacturer product website. if it has a PCIe x16 slot it is compatible.
other problem may be if your case is big enough to fit fullsized GPU. or if you have the 6/8-pin power connectors available. or if your PSU even has enough power to run a dedicated GPU.
Theres no 'compatibility' with modern gpus and motherboards, as long as you have PciE slot on your motherboard (You do) and enough power and connectors for all your system you will be fine.
