MSI HD RADEON 4850 - Problem T_T
natuluyan
9
Help.... When I Rate my computer system in windows 7 32bit and when I playing 3d games my Monitor Crash and the d1601 led is ON.. and when I check my Temperature... is shows 60 celcius... what is the problem? can you help me anyone...
GPU - MSI Ati Radeon HD 4850
Have you done a clean install of the drivers, uninstall, grab driver sweeper, reboot into safe mode, run driver sweeper, highlight AMD - DISPLAY hit analyze, then clean, reboot out of safe mode, reinstall drivers.
Also are those temps take at idle or under load? if idle they are a bit high, I would run furmark if the clean reinstall doesn't fix anything. Monitor the temps closely when its running to see if its overheating.
i haven't tried that... but my Windows is Fresh... still... have the same problem...
my PSU is 450 watts with 6 pin connector... do you think... that my problem is my psu?
yeah the d1601 led is on... they say it is over heating... my computer idles at 53-55 and crashes at 63 celcius....
do you think.. that my GPU isn't getting enough power...?
