Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
Okay I just tried about everything & this is what i’ve done:
1. Boot windows xp original -non sp1/sp2
- every driver and hardware peice works good
- Radeon 9800 pro runs good, no problems here.
2. Upgrade to windows xp sp2 pack
- constant crashing of Radeon 9800 pro
- screen goes black, or blank, or crash
- did not crash with older radeon 64 agp card
3. Updated every possible bios, drivers etc.
- did some voltage tweaking for apg and ddr
- same results, screen still goes blank running an app.
- unplug all hardware except video card, ram, cpu, hard drive & still
crash
System:
AMD 64 3000
MSI k8t neo 2 f
2x512 Samsung ddr400
120gb sata drive
Ati radeon 9800 pro 128mb 256bit
450w psu (26a +3.3v/35a +5v/15a on +12v rail)
changed it to 420w psu @ 18a +12v rail, same results
I haven’t ruled the possibility of a better stronger psu, but it
seemed to run fine until I upgraded to windows xp sp2 with my 2
current psu’s. If i put an older agp radeon 64 card in it runs just
fine? Weird? But I haven’t tried another newer different card cause
I don’t have one. Can it be just that Windows SP2 is the problem
then? Cause it didn’t start crashing until I update it to sp2. If I
downgrade again then everythings works. BTW, I don’t want to
downgrade back again.
One other problem.. no matter what I do I can’t get the bios to run at
400mhz ddr bus speed in dual channel. It only reads 333mhz, and the
HT speed is only 1000? I thought the amd 64’s ht speeds were 2000!
I really starting to dislike the AmiBios, the award bios is so much
easier.
Any help would be appreciated...
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/MSI-Microstar-K8T-NEO-Mobo-problems-Radeon-9800-Pro-ftopict59507.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=301198
crash
System:
AMD 64 3000
MSI k8t neo 2 f
120gb sata drive
easier.
