Question MSI MAG A650BN ATX 650W 80 PLUS BRONZE or Cooler Master MWE Bronze 650 V2?
Dec 13, 2023
5
Hello everyone, may i know which one is better, MSI MAG A650BN ATX 650W 80 PLUS BRONZE or Cooler Master MWE Bronze 650 V2? Or are both bad?
These two are pre-assembled computers that I want to buy. Which one do you think is better?
Processor : AMD Ryzen™ 5 5500 (6C,12T - 4.2Ghz Turbo)
MotherBoard : ASUS Prime A520M-K
Memory : Apacer PC DDR4 16GB 3200Mhz
Graphic Card : COLORFUL RTX 3060 NB DUO 8GB
Storage : PNY CS1031 M.2 NVMe SSD - 500GB
Power Supply : Cooler Master MWE Bronze 650 V2 - Flat Cable
Processor : AMD RYZEN 5 5500
MotherBoard : MSI A520M-A PRO
Memory : KINGSTON FURY BEAST BLACK DDR4 16GB 3200MHZ
NVME SSD : XPG SX8200 PRO PCIE GEN3x4 1TB
Graphic Card : ZOTAC GAMING GEFORCE RTX3060 TWIN EDGE V2
Power Supply : MSI MAG A650BN ATX 650W 80 PLUS BRONZE
You should look into a DDR4-3600Mhz dual channel ram kit. make sure you're on the latest BIOS version for either board you pick and you should be good.
Just for context, you haven't stated where you're located, what your budget is and what the build would be taxed with. These help decide if your deal(for the builds) are well worth it. This site is based in the US so the folks here would tend to see prices/product availability with regards to 'State side.
I feel like you could revamp your list with a better build.
That being said, you posted this thread in the power supplies section. Are you asking for feedback on the PSU or the builds? If the former, then MSI unit. If the latter, you've posted in the wrong section. I'd advise on posting another thread for the system's in the System's section.
The MWE Bronze 650 v2 is much better, but that's not saying much. Between those two systems I'd definitely take the one with the CM power supply if the PSU is the main concern. Be aware that the MWE v2 is known for "clicking" which is due to the PSU going from resonant mode to burst mode, and is not a "problem" but is merely an attribute of platforms using burst mode.
Sorry for causing trouble to you, I will post it in the system section😅
Got it, thanks for your opinion😁
