Hello. I bought a $129 Gigabyte B450 Auros Pro WIFI to buy with a Ryzen 5 3600 and 16 GB RAM. It is still shipping to me. I saw that there is a MSI MAG B550M Mortar WIFI for $170 being released on June 16, which is $40 more. I could return the Gigabyte. The Gigabyte has slightly better sound and is $40 cheaper, but the MSI will have B550, PCIE4.0, WIFI 6, Bluetooth 5 (instead of 4.2) and better VRAMS. It is also more likely to support Zen 3 since I will probably upgrade to it once Zen 4 comes out. B450 will support Zen 3, but could potentially not have all the features or not at all based on which board. After Zen 3, they will probably go to AM5 and DDR5. Are these reasons worth it to spend $40 more? I don't need WifI 6, and no GPU today benefits from PCIE 4.0. Any SSD that uses it is also not worth it to me over a normal SATA SSD since the loading times for games and windows is at most 3 seconds different. I most likely want to keep the motherboard for 5 years, so is there a possibility PCIE 4 will become useful in a mid or low-end GPU in 5 years? A 2080-Ti doesn't use it, but a RX 5600 XT apparently does?
Will I miss out by not getting the MSI B550? Is $40 more worth it for futureproofing? I feel like I already spent a lot on the Gigabyte B450. Should I just stick to what I bought already? Thank you.
