[SOLVED] MSI MEG X570 Ace Debug Code LED Constantly Changing
Hamza Ensar
Commendable
Jan 31, 2021
42
Good day to everyone. I didn't encounter this problem until I updated the BIOS. Debug Code LED keeps changing. Is this a problem? It doesn't cause me any trouble.
https://drive.google.com/file/d/1-v3x_pm3cFGReML9gX_GOnr91mQxqpBK/view?usp=sharing
My computer:
Ryzen 5 5600X,
MSI MEG X570 Ace,
Corsair Dominator Platinum RGB 4X8 3600 MHz CL14,
GT 1030(I will replace it with the RTX 3080.)
MSI MAG CoreLiquid 360R,
Corsair RM850X.
Note: BIOS is up to date.
This would lead me to believe it's not error codes.
Read this: https://www.overclock.net/threads/d...ing-down-from-40-to-30-over-and-over.1740508/
Forsaken1 said:
Debug led reads cpu temp.Can turn off in bios.
I'd recommend looking for such a setting in your BIOS to verify this. Then you can decide to disable it, or leave it enabled and look at it as useful info.
Reference: See this answer from a similar motherboard: https://forums.tomshardware.com/threads/motherboard-ez-debug-led-shows-36and37.3484910/
Reactions: Hamza Ensar
