Hello,
I have built this system:
Psu : FSP 700-60AHBC
Mobo : MSI B450 Gamin Plus Max
CPU : Ryzen 2600
GPU : MSI GTX1650 Super XS OC
RAM : CORSAIR Vengeance LPX DDR4 1x16GB 3000 Mhz
Firstly, i did not flash the newest bios (used whatever it was) and assembled that way. When i powered on, i could not pass from CPU post. CPU Error Ez Debug Led remained red without blink. Then i dissassembled all parts. I only connected CPU and Mobo connections of PSU(no cpu, ram, gpu etc.) as instructed in the flash bios button section of the motherboard manual. I reset CMOS by extracting and replacing CMOS battery. I connected a usb drive (which i formatted to FAT32 and in which only file was MSI.ROM) to Flash Bios Usb Port of mobo. I pressed the flash bios button. The led starting blinking a few seconds later and remained blinking a few minutes. Then the system reset itself. I did and observed these as the manual instructed. The BIOS version i used is 7B86vH6 on site: https://www.msi.com/Motherboard/support/B450-GAMING-PLUS-MAX#down-bios
Then I assembled again all parts. Now when the gpu power connector(6 pin psu connecter on my GPU) is disconnected, when i press the power button, first cpu red led is lit. 1-2 seconds later it is not lit anymore. A few seconds later VGA led is lit and it stays that way. GPU is not powered on(no led or fan) as expected, i think. From this, i understand that flashing made an effect, because i could never pass CPU red light error before.
The problem is when everything is assembled + gpu 6 pin power connecter is also connected. When i press the power button, the CPU red light is lit and stays that way without blinking. I think, GPU is not powered on again since no led or fan. The GPU was firstly in PCIE 3.0 x16 port. I also tried the other PCIE 2.0 x4 port (other plastic long PCIE connector below) and the results are same.
Okay, I thought if it was about GPU, why mobo does not lit VGA red light? The only way i could think was the PSU is faulty, so when GPU is also demanding power, the PSU cannot supply (by the way i believe 700 watt is way more than enough for this system), voltage levels drop and it cannot even supply CPU properly, hence the CPU red light. In order to test this. I measured voltage levels with voltmeter of GPU and CPU power inputs, when all mobo, cpu, and gpu power inputs are connected; and system is powered on. The measured voltage was 12.1 +- 1V (my voltmeter is not calibrated). I supposed the problem is not about PSU. (by the way the PSU came with a coil whine problem)
In all tests, i never modified the system when power was on.
In short:
The problem is told by mobo. Mobo says "problem is about cpu". Cpu says "i am fine if you do not power GPU". Problems happen only when gpu power is connected. Power supply says "it is not my problem". The bad thing is that i ordered parts separately. So if a part is faulty, i have to debug and find it quickly.
The last thing i can do is to continue flashing all 6 previous bios versions published on MSI website, to check if the system can be happy with one of them.
Lastly. Very seldomly even when GPU power is not connected something happens about CPU red light. It starts lit and not lit (as always so far, but after this point it should pass to VGA red light); but then it continues to lit and not lit again and again.
I tried to give as much detail as possible in order not to miss anything. Thank you if you could read..
CPU : Ryzen 2600
In short:
