MSI motherboard EZ-Debug LED flashes between CPU and DRAM when RAM is inserted.
xhgaerlan
Great
Apr 26, 2018
26
After adding a couple of 8GB RAM sticks to my already 16GB system, it worked fine. A couple of bumps here and there, especially after attempting to overclock the RAM, but the system was running smoothly. I was overclocking the RAM to 3300MHz from a base 3200MHz, and managed to get the system to boot, albeit unstable. However, after one attempt to overclock the RAM from 3200MHz to 3300MHz, the system shutdown and now flashes the EZ-Debug LED from a short CPU flash to a long DRAM flash (repeats).
When the RAM modules are removed from the system and the power is turned on, the CPU is correctly detected, and the DRAM EZ-Debug LED remains on. That shows me at least that the CPU works. Whenever the RAM modules are inserted again, the same pattern of LEDs flash. I've tried putting a new, working, and stable module in, and it still shows me the same pattern. I assume that the motherboard's RAM slots are malfunctioning, but I can't be quite sure. What would be the exact issue causing this, and is there any way to get it resolved that doesn't involve RMA?
Edit 1: After unstable overclocks, the system would show a failure message stating that the ME FW is "abnormal". However, returning to stable clock speeds removed the message.
Edit 2: I have already checked out http://www.tomshardware.com/answers/id-3660071/msi-z370-pro-debug-led-cpu-ram.htm, http://www.tomshardware.com/answers/id-3437937/post-bios-display-red-led-flashes-dram-led-cpu-led.htm, and http://www.tomshardware.com/answers/id-3647474/msi-z370-pro-display-boot-debug-led-blinking-cpu-ram.htm.
System Specs:
MSI Z370 Gaming Pro Carbon
Intel Core i7-8700K
G.Skill TridentZ RGB 2x8GB 3200 PC4-25600
Corsair Vengeance RGB 2x8GB 3200 PC4-25600
Thermaltake Toughpower Grand RGB 750W
Misc:
Intel Optane 32GB Memory Module + SK Hynix Canvas SL300 500 GB SSD
Hitachi 5400RPM 2.5" 500GB HDD Storage
Thermaltake Gravity i2 CPU Heatsink/Fan
Thermaltake Versa C22 RGB Case
I tried that, but now I have a new problem. :chaudar:
The motherboard now boots, but now the boots drive seems to have been corrupted. Will try to find a solution in another thread. Thanks!
I tried that, didn't work. Ended up being a short for me. Not sure where, but remounting the mobo worked.
