*updated please check bottom post*
I will try to make this a TL;DR please bear with it and thanks for looking for it and any help/ideas you might have is very welcome.
Hard to explain with out some back details.
PC has been working perfectly fine. While sleeping on top of the desktop a cat presses the shutdown button, PC shuts down "windows is shutting down" splash screen and all.
Turn PC back ok and nothing shows up on the monitor. I test other monitors and nothing is showing up.
I unplug the Desktop from Back Up Power Supply to wall outlet (trying to remove any possible lines of causes). PC and Monitor boot up and monitor works.
I'm shown a EFI splash screen that is looking for the drives (two drives are in the monitor, one 2TB HDD and 1 64 GB SSD).
This screen just sits there till I press the power button witch just turns off the PC.
THIS seems like the drives are NOT getting enough power as if the PSU some how has gone bad. It's a Corsair RMX650 bought with in 6 months.
So, I ordered a new PSU and gonna change it out and start narrowing down the possible reasons.
I have also..
moved the SATA cables to different ports (nothing changed).
reset the MSI X99S SLI Krait Edition mother boards bios to default (nothing changed)
So at the moment I'm just.. waiting for the new PSU so I can narrow down reasons. I assume it would have to be the PSU or possibly the motherboard?
if you made it this far thank you for taking the time to read, if you have any ideas/suggestions please let me know.
I have also..
