Question msi motherboard works fine, but doesn't post to monitor
Jan 19, 2024
11
b350 gaming plus, worked fine for 6 months then one day it didnt work, tried 3 different ram kits and 3 different gpus, tried all 4 ram slots saperately, or 2 or 4 ram configs, different pcie slots, 4 different cpus, it powers on, cpu debug led goes on for a second then goes off, everything is running, but no display.. resetted cmos, tried simple tricks like powering psu off/on quickly, is this fixable or does anyone know what would be wrong with it to try and find someone who can fix it? thank you.
it "worked" fine, but how do you know if its "working" fine now? since you've tried with a bunch of different components, all i can say is either there's a loose connection or its dead.
worked is the past tense, it worked before like a normal motherboard, and one day it suddenly stopped posting to screen. we checked the cables too to make sure they're tight
if you dont know if it works now, how can you say if its working now? so my guess is the mobo is dead, as you've tried almost all the troubleshooting steps, and it still doesn't work. :worried:
it literally works though? as in power on and power all the components, my problem is it doesnt show anything on the screen, so im hoping someone knows where the problem lies so we can change or hit something with a stick to get it running.
If it has an integrated GPU, try putting the HDMI cable/other cable into the slot on the motherboard.
that would be great but the board isnt updated, so no second gen cpu support. im thinking it can also be using something other than the hdmi port but now i dont have a hold of a cpu to test..
