Question MSI MPG b550 carbon wifi, Ez debug led cpu
May 16, 2024
I have a Ryzen 5 5600x, I got the new motherboard, except that after assembling everything, the CPU LED on the Ez debug remains lit, I updated the BIOS with the USB stick with the latest update released, but the problem still remains, I tried to search online because I was unsure if it was the CPU power supply, since I have an EVGA 600 br plus bronze which only has the PIN 8 and not 8 + 4,I ordered an adapter from 8 PIN to 8+4 PIN, I don't know if it will fix the problem.
Below I have put my components in case they are needed to understand the problem.
CPU: ryzen 5 5600x
Motherboard: MSI MPG B550 carbon wifi
RAM: 8x4 Corsair vengeance 3600 MHz
GPU: MSI RTX 3050 ventus 2x 8gb
Power supply: EVGA 600 BR plus bronze
I hope to find a solution, otherwise I will have to reassemble the old motherboard.
CPU: ryzen 5 5600x
pretty sure that power supply comes with 2 8 pins for graphics card
PCIe2x 8pin (6+2)
EPS (CPU)1x 8pin (4+4)
also noted make sure the correct cables are inserted you should not need a adapter for anything if your using the correct cable
plugging the wrong cable in will damage the motherboard
sono abbastanza sicuro che l'alimentatore sia dotato di 2 8 pin per la scheda grafica
PCIe2x8 pin (6+2)
EPS (CPU)1x8 pin (4+4)
nota inoltre che assicurazioni che siano inseriti i cavi corretti, non dovrebbe avere bisogno di un adattatore per nulla se stai utilizzando il cavo corretto
collegare il cavo sbagliato danneggerà la scheda madre
the power supply only has an 8 PIN (4+4) for CPU, but on the motherboard there is an input for an 8+4 PIN as power supply, I looked online and they say that the additional 4 PIN for powering the CPU is only needed in case of overclocking the CPU, but I updated the BIOS and all the other components are working, I don't know what to do at this point other than trying to insert an 8 + 4 PIN as power supply for the CPU instead of the normal 8 PIN
personally unless your planning to overclock then i would send back the board i have had more issues with msi on these forums if you have to use a adapter i personally wouldnt use it even if it was for overclocking
go with something like asrock or gigabyte
Latest posts
