Hi all I have a msi mpg x570 gaming pro carbon wifi
The Ethernet port is not showing up under device manager after the computer came back on after having the power out the PC was on an up and I was able to shut it down but if I look in device manager I can see the Wi-Fi Internet but I do not see the Ethernet port at all and I've even tried a different cable on the Ethernet port and I've looked in the BIOS to make sure that the Ethernet port is enabled and it says it is enabled this is on a system with Windows 11 Pro what are the steps could I do to try to fix the Ethernet port on the method board it was working fine prior to the power outage and not having power back on for how much the day and a half thanks for any advice Beau
