[SOLVED] MSI MPG z390m Gaming Edge AC or Asrock z390 Phantom Gaming-ITX/AC for overclocking?
Feb 4, 2019
Which is better for overclocking, MSI mpg z390m Gaming Edge AC or Asrock z390 phantom gaming-itx/ac? I have read up on the Asrock z390 itx board and it has rave reviews, just cannot find much on the MSI mpg z390m. My objective is to have a z390 mATX or mITX board in this overclocking rig as it is a smaller case, so if there is a better option between these two (or besides these two) I would like to know your opinion.
my current setup
CPU: i7-9700k
CPU Cooler: Corsair - H100i RGB PLATINUM
GPU: Gigabyte RTX 2060 Gaming OC
SSD: HP EX920 1TB
PSU: SeaSonic - FOCUS Plus Platinum 850 W 80+ Platinum
CASE: Corsair Air 240
Things I care about
- overclocking ability
- fan/RGB headers
- dual m.2 NVMe slots that don't hamper performance/connectivity when both in use
Things I don't care about
- WiFi
- Audio codecs
- thunderbolt
- onboard graphics connectivity
- using more than 32GB or RAM
- multiple GPUs
- LEDs to an extent
Thanks in advanced!
