MSI N640-4GD3 GeForce GT 640 4GB 128-Bit GDDR3
Lppr Falcon
45
Can you tell me more information about this graphic card / video card?
MSI N640-4GD3 GeForce GT 640 4GB 128-Bit GDDR3 PCI Express 3.0 x16 HDCP Ready Video Card
if you get a chance to open your case and look at your power supply then it needs to be at least 400w with 1 pcie 6 pin connection. if you have less than 400w or no pcie connection (you can get adapters for other connections if you have any) then the best you could get would be a gtx 750 ti
How to make sure?
Ok, thanks for your help. I will choose gtx 750 ti then.
