Msi netbook wireless problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
hi! i need to know how to fix my msi netbook...i can't connect with any wireless connection although i have my own wifi connection on my room...and i try to do the "ipconfg" and it shows that media disconnected....i really don't know what to do...please help...
There may be a physical switch for the wireless adapter on the front edge or side of the laptop -- otherwise it may need an Fn key combination. See the literature which came with the computer.
If you are confident that you've turned on the adapter go Control Panel, System, Hardware, Device Manager and see if the adapter is present or whether it is yellow flagged as faulty.
May just be a matter of downloading a later driver from MSI.
