MSI P55-GD80 M-Flashing problems
trentv4
Recently I tried to update my BIOS through the MSI LiveUpdate. In the middle of using the install, I got an IRQL_NOT_LESS_OR_EQUAL bluescreen and exit. When rebooting, I had to make a flash drive with the latest (1.C I think) BIOS revision. I can get all the way through repairs up to the CMOS Setup Utility. The only option is >M-Flash. Under M-Flash and then "M-Flash Funtion as", I can select Disabled or BIOS Update. When I select update, a grey-ed out "Load BIOS Source File from" selection appears with the usual selection box labelled as No Media.
What next? I've had my board for a while and got it second-hand, and due to time RMAing is pretty much not an option. I have no spare motherboards.
