[SOLVED] MSI PC suddenly wont turn on and has 3 blinking red light on top left
Sep 5, 2020
5
Spec: EVGA 400W psu
Amd Ryzen 5 2600
Hi my PC has been fine for almost 1 and half year now.
Suddenly it wont turn on.
When I connect the PSU there is 3 blinking red light on top left of motherboard near I/O.
When I power on the fan runs half a second then its dead. After that if I power on nothing happens.
My likely suspect is PSU at the moment but any advice you guys will have will be amazing.
Thanks,
Sep 5, 2020
5
Hi Guys this is solved it was PSU.
I bought new PSU and voila worked,
I tried again with my old PSU and same problems.
EVGA PSU broke within 1.5 years of use.
Thanks for all your inputs
Sep 5, 2020
5
Have you tried clearing the CMOS?
Have you tried booting with no drives connected to see if you can get into the BIOS?
Hi so far I have tried these.
  • clear CMOS through JBAT-1
  • clean ram slot, tried different ram slot
-tried booting with no drive
When I unplug the PSU power cord and rejoin this red light blinks 3 times,
Well I have a new PSU arriving tomorrow.
I am just worried if it is not PSU then what am I looking at.
At the moment I am just have CPU, with CPU heatsink and fan, Ram plugged in nothing else.
I have plugged in CPU and ATX plugged into PSU.
Please share any of your knowledge on these.
Thanks
Thanks
Is the motherboard outside the case?
Do you have 1 stick of RAM located in slot DIMM_A2?
Sep 5, 2020
5
