Question MSI PRO 650-A EZ LED CPU/DRAM after 2+months of running
Nov 3, 2024
CPU:AMD Ryzen 7 8700F (4.1 Ghz) - Ryzen 7 8000 Series 8-Core/ 16-Threads, Socket AM5, 65W Processor
CPU cooler: Stock in box of CPU
Motherboard: MSI PRO B650M-A WIFI AM5 AMD B650 SATA 6Gb/s DDR5 Ryzen 7000 Micro ATX Motherboard
Ram:G.SKILL Ripjaws M5 RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 5200 (PC5 41600)
SSD/HDD: 3 SSD
GPU: ASUS Dual AMD Radeon RX 6400 Gaming Graphics Card (AMD RDNA 2, PCIe 4.0, 4GB GDDR6 Memory
PSU: EVGA 400 N1 100-N1-0400-L1 400W Power Supply (Bought 2019)
OS: Debian 12
Monitor: Samsung CF390 Series 27 inch FHD 1920x1080 Curved Desktop Monitor
Haven't updated bios yet from what is shipped.
Hello, I recently built a computer in September, and today, while it was left on, had the EZ Light DRAM (yellow) illuminated. The computer was un-repsonive and a re-boot I now have both the EZ lights for CPU/DRAM illuminated.
Some history, it has been a troublesome build. My first motherboard was the ASRock B650M PG RIPTIDE WIFI AM5 Micro-ATX Motherboard. The on first power on had EZ lights for CPU/DRAM illuminated. Did some troubleshooting and decided to RMA. The replacement was same issue! I returned for refund and ordered the MSI motherboard. After waiting ~5 minutes, it finally booted and I was installing debian.
Everything was running great, I just had an ongoing issue where debian was crashing due to [gfxhub] page fault on my GPU. I started with troubleshooting hardware. I installed a XFX Radeon RX 580 GPU and took my Thermaltake W0106RU 700 W (yes from 2007) from my server PC since the 400W could not support it. After a week of no crashing, I installed my RX 6400 GPU again with 700W PSU and crashes happened again. The fix was to update my Mesa drivers through debian backports to 24.2 if I recall. I have been using my PC great with no crashes for 3-4 weeks now.
Today I had a browser open and was updaing nextcloud on the server PC. I took a 3 hour phone call, came back and that is when I saw the DRAM EZ light on and the keyboard backlight was dead.
My old PC was using an AM4 socket and DDR4, meaning I have no "good parts" to swap. What I have done so far
+ Re-seated RAM
+ Use only one RAM at a time
+ Tried all sockets
+ Clear CMOS
+ Removed GPU
+ Remove RAM, power on, power off, re-install RAM
The PC draws RMS 0.331 A off 120VAC. I measured +12.3VDC, +5.1VDC, +3.34VDC
I am at a lost what to do or how I can isolate it. My wifes PC is an intel, but has a ASUS ROG Strix B760-I Gaming WiFi Intel B760(13th and 12th Gen) LGA 1700 mini-ITX motherboard. Could I install my RAM and run MEMTEST86? I assume since the CPU error LED is on I have no means to test on my PC. Any guidance is appreaciated.
And what BIOS version were you on out of the box?
I would've replaced the PSU while you were upgrading the platform, if I were you;
Tier F
Just my observation, you seem to have bad PSU's at your disposal for concurrent hardware. To add, did you reinstall your OS when you replaced the motherboard?
Tier F
Hi, you are right on the money :) I took my old Thermaltake PSU and the PC booted right up with no issues. Thanks for the list, that is very helpful and I will use that for the replacement. Thanks again!
