MSI R7 370 Keeps crashing and recovering, please HELP!!!
Gimsta
Commendable
May 27, 2016
8
Hi, i just built a new computer just recently, and i noticed that i got one faulty RAM stick; for some reason the RAM stick works, when i put two other RAM sticks(Different brand). But other than that, the real problem is that my GPU keeps crashing and recovering, for every type of game i load. I tried every possible thing, however it does not seem to work. For instance, i reset the computer more than 3 times, wiping everything in its way. I also did the TdrDelay, but that doesn't seem to do anything; in fact i get a new error saying that my graphics card was blocked. Anyways, i just wanted to know wether or not its my RAM, or the GPU. I also just ordered two new pair of the same RAM sticks, and plan on seeing if everything is in order. Any help would be appreciated, thanks!
Computer Specs:
Motherboard: MSI 970 AMD Gaming Motherboard
CPU: AMD FX-6300 6 core Vishera Black Edition
RAM: Corsair Vengeance Pro 16GB DDR3 2400MHZ (2x8) (one is faulty)
HDD(s): 1 TB WD Black 7200 RPM
500 GB Seagate 5200 RPM
GPU: MSI R7 370 4GB
PSU: EVGA Supernova 650 G1 80+ Gold
LazerL0rd
23
The Real Problem, Which I Had Myself. Is That VSR (Virtual Super Resolution) Is Enabled. True Support Isn't Available In Applications A Few Years Old. So You Must Disable, Then Enable, Then Disable VSR. It Will Then Fix. ;)
Gimsta
Commendable
May 27, 2016
8
Gimsta
Commendable
May 27, 2016
8
I actually fixed it. My windows was either corrupt, or it had a virus, and i believe that is what caused the problem. All i had to do to fix this issue, was just clean install windows from scratch, instead of reseting it to factory new, etc.However if i do encounter the same problem, i will try your method, and see wether if it resolves the issue. Also, thank you for answering my thread, really appreciate it :D
