I sent an email to msi tech support to see what they say but I also thought of coming here and seeing what you guys might suggest. I’d copied and pasted what I wrote in the email. If you guys have any suggestions I greatly appreciate it.
I am having a issue with A couple of the motherboards that I purchased. The first one that I returned was a b450 gaming plus max. To let you know that I have 2 sets of 8 gb 2666mhz ddr4 ram and 1 set of 16g 3200 MHz ddr4 ram which I know is to powerful to use at the start but only put it in to show if there’s power going through when it lights up. And my cpu is a amd ryzen 5 3500 which I believe has no intergrated graphics so I have to use a Radeon rx550. I tried everything on it from using 1 ram and resetting cmos on the motherboard, and following up doing a flash bios on it which it accepts it but the dram led still showed up and no signal to monitor which I know the monitor works well with other devices. I ended up concluding that the motherboard was bricked and ended up returning it.
Now I have a b450 gaming pro carbon max wifi and still having the same issues. Do you have any suggestions such as getting a new cpu with integrated graphics or could this motherboard I got now is bricked? I really don’t know what to do at this point any suggestions is appreciated
