Question MSI RTX 2080 Gaming X Trio small fan not spinning
Sora424
Commendable
Jul 6, 2017
19
Hello, as the titled said while idle all three fans not spinning but when I play games two big start spinning, the small one don't .
So how I can check if this fan working or not. I just bought GPU three weeks ago.
Oct 16, 2019
80
7
35
The small fan is controlled separately from the 2 bigger fans and it starts running on a higher temperature.
To make sure it is working, try running Benchmarks for longer period of time until your graphics card reaches 65+ Celsius
Oct 16, 2019
80
7
35
Just google for 1 and take any that can benchmark your GPU. Leave it to run for a while untill your GPU temperature rises (i mentioned that before) and you will confirm whether the small fan is actually working at 65+ ish celsius
Sora424
Commendable
Jul 6, 2017
19
I done the test but still not spinning. Turns out that the stand that comes with RTX was blocking it. I removed it and it's ok now.
