I know the fan make some noise under load but the fan are making a noise like hitting something. I don't know if someone has the same problem.
can u remove it from the slot and send a photo of the fans
turn everything off firstcan u remove it from the slot and send a photo of the fans
is that yours or is that a image from the internetI don’t know if you can work with that
thank youDude, he can get an image of it from the internet with a google search. He wants to see YOUR GPU to see if there is something he can identify causing the noise.
I have the same GPU as him so I compare the image to mine bc mine doesn't make that noisethank you
Я знаю, что вентилятор издает некоторый шум под воздействием, но вентилятор издает шум, как если бы он ударялся обо что-то. Не знаю, есть ли у кого такая же проблема.
