Can we use the 12V-2x6 Cable to power the GPU instead of using the Y-Cable?
PSU only came with 1 6+2 PCIe cable.
Thanks.
Thanks.
You mean the adapter that adapts PCIe connectors to a 12v-2x6 connector? If so, that's meant for PSU's that lack a native harness for the 12v-2x6 connector. Since your PSU has one out of the box, yes you should take advantage of it.
Just make sure the connector is fully seated on both the PSU's end and the GPU's end.
On a side note if you feel like giving some advise on a case fans thingy let me know.
Start a new thread in the Cooling section. The community will chime in.
