i bought this gpu from msi and it arrived today, i upgraded from an r7 260x and when i realized the drivers for the GPUs where compatible i still had uncertanties and did a complete uninstalling of the drivers and installed crimson 16.9.2 again. i also dont have a cd drive so i thought downloading the msi gaming app so i downloaded the msi gaming app and downloaded afterburner as i was on the same page too, the thing is the fans are a complete utter mess and have no rational working whatsoever. at first i didnt touch wattman, or gaming app (only to change led color), or afterburner to change the speed of fans, but i inmediatly realized that the gpu was at idle at 56-8 degrees c with the fans completely off. i thought that was just software feature for it to stay silent but as i launched my first game to test fps the fans did not go on until the gpu hit 75c and instead of gradually going up it went to an immediate 100% and full leafblower mode for 5 minutes, even though the gpu reached 28c in a matter of seconds. after those 5 minuets the fans went back to 0% and back up to 100% when temps got bad for another five minutes, this incredibly annoying pattern went on for about an hour until i decided to launch wattman to see if i could change the settings the fans speed was put.
wattman proved to be completely useless as even after seeing some tutorials on youtube no matter how much sliders i changed and numbers increased or decreased the fans had no change whatsoever. so i reseted wattmans settings and decided to launch speedfan and again, absolutely no change whatsoever. at that moment i decided to see if afterburner helped so i restart my computer (again) and set up a preset that gradually increased the fan speed to whatever temp i chose, and it worked for like 20 minutes until i was total war: attila and it went above 40c and it went up to 100% for like another five minuets and then went back to 0% and stayed in 0% all the way up to 89c and my gpu severly thermal throttled. this has gone on for hours upon hours of me restarting the computer and i see the same pattern over and over again. i have to turn off my computer every certain time even while browinsg chrome because the fan will stay at 0% forever and i fear for my GPU exploding.
my specs are:
amd fx 6300
windows 10 64 bit
8 GB of ram
corsair CX500M psu
MSI rx 480 4gb
my specs are:
amd fx 6300
windows 10 64 bit
8 GB of ram
corsair CX500M psu
MSI rx 480 4gb
