I have purchased this board and while putting it together.
I noticed the CPU power block has 8 pins.
Four are blocked off, only four are exposed.
My BIG power supply only has an 8 pin 12v block.
no four pin block for 12v.
Why are the left-most pins blocked off?
I had to use a smaller powersupply to get a 4-pin connector.
Can I just remove the cover on the MB?
http://www.msicomputer.com/product/p_spec.asp?model=P6N_SLI_Platinum&class=mb
its the block at the bend of the heat-pipe.
Anyone know why it is capped off?
And if the cap can safely be removed?
