Hi all, having some problems with my Ventus 4070 Ti
The card's thermals seem to be quite high during idle and I'm confused as to why.
I've got nothing running that would use any GPU resources (Firefox, Discord, etc.) and yet my idle temps are always in the low 50s - low 60s.
The Ventus has a 0 RPM mode which seems to turn off after it hits 60 degrees and turns back on after dropping to low 40s, yet as soon as they turn off, the temps jump back up to 50-60 in the matter of a few minutes.
Temps during gaming are also quite confusing, ~65 degrees on Valorant, ~75 on CS2. All in 1440p.
The fans also get pretty loud because of the high temps and them needing to run higher RPM's to keep up.
I'm running the card in an NR200P, with 2 exhaust fans up at the top, and a Thermalright PS120SE pulling air in from the back.
Anyone with this card have any experience with such temps? Thanks
